blend door actuator
Old Feb 1, 2013 | 7:34 PM
stemwall's Avatar
Default blend door actuator
i need help... i just installed a new blend door actuator on my 99 silverado Z71 5.3 LT.I am confident that I have the right part (after much research) and it installed no problem. I went through the steps on how to reset but the cold/hot blend control is working backwards. Turn it to cold and its hot turn to hot and its cold I installed a Dorman 604-113 is my reset not working any help would be great thanks .
Old Feb 1, 2013 | 8:22 PM
Did you plug in the power before installing the actuator? If you do this the actuator motor will turn making it very difficult to get it set right. I put one in my 99 and it worked correctly.
Old Feb 2, 2013 | 8:01 AM
stemwall's Avatar
Thanks for the reply no i did not plug it in before install. do you have any suggestions on the best way to reset there are a lot of different opinions out there <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
DaniGirl
Jul 23, 2015 6:14 PM
JoeCB
Uplander
26
Mar 11, 2014 3:28 PM
Jack
Sep 20, 2009 2:33 PM
2006trailblazer
Feb 24, 2009 1:58 PM
