Bluetooth Kit for 08 Silverado w/ CD Nav
Old Jan 29, 2008 | 3:41 PM
rmbudd3's Avatar
Default Bluetooth Kit for 08 Silverado w/ CD Nav
I have an 08 Silverado w/ Nav. Following the advice of some on this forum, I bought a coastal e-tech onstar lockpick and a Parrot CK 3500 bluetooth handfree kit. I had the system hooked up at the local Best Buy, but we have encountered a problem. The handfree kit works perfectly for outgoing calls, but not for incoming. On incoming calls, the kit switches to onstar when the phone rings, just like it is supposed to, however, once you answer the phone the onstar cuts off and the radio comes back on and the only way to continue the call is through the cell phone handset. Has anyone else encountered this problem? The Parrot rep says its the Lockpick, and the Lockpick guy thinks its the Parrot. Well, I have now to be on the safe side bought 2 of each, so one of them must be wrong. Any thoughts or suggestions would be appreciated. Thanks.
Old Jan 29, 2008 | 8:40 PM
shawnvw's Avatar
Banned
Default RE: Bluetooth Kit for 08 Silverado w/ CD Nav
what was the point of the lockpic thing?.....If wired properly, the parrot should be able to be integrated all by itself.
Old Jan 30, 2008 | 6:25 PM
shawnvw's Avatar
Banned
I just installed a ck3200 today in an 08 CTS, I am 100% sure that you can do these units without that lockpick thing........I would start by taking it out and see how th unit performs after that
TMW597
Dec 30, 2021 2:59 AM
Boris
Nov 4, 2012 9:54 AM
gm_geek
Jan 31, 2009 4:08 PM
rmbudd3
Jan 29, 2008 6:50 PM
