Notices
bow tie
Old February 13th, 2010, 8:42 PM
  #21
s34n's Avatar
ok. paint you used?
Old February 13th, 2010, 8:46 PM
  #22
992door's Avatar
duplicolor color and clear and just some primer that i had around the house
Old February 13th, 2010, 8:58 PM
  #23
s34n's Avatar
think there is a difference between the duplicolor spray paint and normal paint?
Old February 13th, 2010, 9:00 PM
  #24
992door's Avatar
i dont know i doubt it
Old February 13th, 2010, 9:10 PM
  #25
s34n's Avatar
i looked on duplicolors website and my color code wasnt on there.
Old February 14th, 2010, 6:28 PM
  #26
cams 98 silverado's Avatar
few things... chrome is a chemical bonding. you cant paint over chrome. that paint will flake in a year unless you sand it down. and if you wanna paint the stock tie, just use 300 grit or so, primer it, wet sand it, color, sand, color, sand then clear. when wet sanding i used 700 on the primer, and color sanding i used 1000. then just shoot some clear let dry and your gold. a nice even no orange peel result. and to get the emblems off, you can use fish line but the trick, get some 3m adhesive remover spray it above the part to be pulled off, let it run down, let it soak then slowly use the line to break the glue loose then peel the rest of the sticky off the truck and buff it up. if you use a heat gun, well personally i would never recommend one unless your doing it out in the cold. heat guns can increase oopsies very fast. if heated too much, can crack paint and so on. or, go to youtube and look up how to remove decals. guy did it with a rubber spatula, wd40 and a microfiber over the spatula. ya mean.
Old February 14th, 2010, 6:45 PM
  #27
s34n's Avatar
well i was going to paint my gold one i have but no paint store nor parts store that will make the paint and there are plenty of body shops in my area so im going to go by a few tomorrow and price this job out.
ericseattle07tahoe
June 23rd, 2008 8:34 PM
projekt4
July 3rd, 2007 4:13 AM
dcarreiro
June 12th, 2007 10:03 PM
massattitude
May 4th, 2007 5:51 PM
P_RsTahoe
January 29th, 2007 4:02 PM
Quick Reply: bow tie
