Brake Light Problem
Old Jan 13, 2013 | 11:32 PM
bigjonxiii's Avatar
Default Brake Light Problem
I have a '08 Silverado 1500 W/T reg cab, long bed. And the all 3 brake lights are doing the same thing. When I barely push the brake pedal the lights flash for an instance but don't stay on, BUT when I push the pedal more than half way the lights stay on. I've already had the stop light switch replaced. Any other ideas on how to fix the problem?
Old Jan 14, 2013 | 6:51 AM
markshop's Avatar
Stop light switch not adjusted properly.
Old Jan 14, 2013 | 1:21 PM
bigjonxiii's Avatar
How do you adjust it properly?
Old Jan 14, 2013 | 5:52 PM
67Motorcat's Avatar
I don't believe the switch is adjustable if it is similar in design to the 99 to 06 models,I am assuming it is.
That being said,remove it and snap it apart,check the contacts and the plunger for proper operation?
Replace with a Napa or OEM switch...the cheaper brands are known not to work correctly out of the box.
Old Jan 14, 2013 | 7:53 PM
bigjonxiii's Avatar
any other thoughts or help?
Old Jan 14, 2013 | 8:05 PM
kevinkpk's Avatar
Same here, sounds like the spring, replace it again, new dosen't mean good.
Old Jan 14, 2013 | 9:03 PM
bigjonxiii's Avatar
I just want to make sure it can't possibly be anything else before I replace it again.
TruckManDan
Dec 25, 2014 7:52 AM
kaptain howdie
Dec 16, 2014 8:20 PM
Slobby Baymon
Nov 12, 2013 11:52 PM
ericmckinney
Uplander
Oct 14, 2011 10:35 PM
beckya99
Jul 12, 2011 12:29 PM
