brake lights fuses keep failing
Old Jul 2, 2009 | 7:27 PM
foxfire's Avatar
Default brake lights fuses keep failing
I have a 1995 1500 Z71. Both of my brake lights wouldnt come on but the center brake light above the cab would. I found out that it was just a burnt fuse so I replaced it and it worked. Then found out the next day that the lights were out again and it was another fuse that failed. Any suggestions why? I would really appreciate it. Thanks.
Old Jul 2, 2009 | 7:30 PM
suzuki-guy's Avatar
Sounds like you got a short somewhere check out the wiring on the brake lights.
Old Jul 2, 2009 | 8:22 PM
MDTAHOE's Avatar
Professional Mechanic
Take a close look at the sockets, they fail often. Also I have heard of entire cars being take apart to look for a short without someone checking the obvious first. Try 2 new bulbs first.
Old Jul 3, 2009 | 7:42 PM
lukemoore646's Avatar
unhook the tail light assemblies and see if it still blows fuses if it does then start at the back and work your way forward, if not then its a process of elimination. one risky but efective way is to put a piece of wire in place of the fuse, hold on the brake pedal and wait for the smoke, i am not responsible for fires and only use as a last resort
Old Jul 4, 2009 | 7:24 AM
Koffietje's Avatar
Was it "another fuse" or "the fuse i used to replace the first one?"
w8ddwn
Jun 25, 2025 1:52 PM
Annstahoe
Mar 17, 2010 3:17 PM
aptget79
Sep 12, 2008 10:28 PM
vhays
Apr 8, 2008 4:48 PM
verle
Jan 28, 2008 9:52 AM
