Old Jul 23, 2015, 7:40 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Brakes
Print Wikipost
Brake Lines...?
Old Oct 1, 2009 | 11:19 PM
Hardwoods's Avatar
Default Brake Lines...?
Hey all I am new here and was just wondering a few things and it looks like some good people on here to possibly answer my questions!! I posted this same post in the general tech section and realized I should have put it here..Sorry!!
I have a 99' Chevrolet Siverado Ex-Cab and just blew my second brake line of the year today..! The truck only has 80,000 miles on it but is rusting out like crazy!! I admit that alot of it is my fault to some extent becuase I generally NEVER drive it maybe 2000-3000 miles a year so it sits alot.
The brake <NOBR id=itxt_nobr_2_0 style="FONT-WEIGHT: normal; FONT-SIZE: 100%; COLOR: darkgreen">lines</NOBR> are completely rust so I figured I will just change out all the lines.........easier set then done....
I call up Chevy garage to get all new brake lines and they tell me they can sell me a roll of line and fittings and have at it...???
Apparently GM does not sell preformed lines for this truck? i would have never thought that!!! I am actually disappointed as now I will have to spend countless hours trying to bend/form/flare all new lines to fit!!!! I have about zero mechanical ability so this ought to be fun!!
I learned a big lesson though, when I buy a new truck IT WILL NOT LEAVE THE LOT WITHOUT UNDERCOATING!!! This should come standard on all vehicles!!
Old Oct 2, 2009 | 11:55 AM
therewolf's Avatar
Call around to the local parts stores.
Some vendors sell pre-bent lines.(Wagner, for instance.)
At the very least, you can buy straight lines with flares and fittings on them.
Tubing bending takes a little practice, you may want to wreck a few cheap lines to get used to it before you start with your vehicles lines.
Old Oct 2, 2009 | 10:04 PM
lukemoore646's Avatar
we all gotta learn sometime and your time is now, you can get a bender and flare tool pretty cheap and go from there, but buy bulk line at a parts store just for the cost factor, its kind of like working with wood, measure twice and cut once, just remember to get home made flares very tight, i have found that they seat a little more difficult than factory flares, other than that have fun with the lines behind the tank
Old Oct 3, 2009 | 9:00 PM
Flying Low's Avatar
Ride of the Month
May 2008
From: Millbrook,Alabama...Slap dab in the middle of God's country
Also if your take on this job, be sure you use the correct tools. Flare nut wrenches are a very good investment. Openend wrenches tend to deform flarenuts at the torque required to seal a steel flare line. Also get some good information on the flare diameter it should be available from whoever makes the flare tool. I have been in the tube fabrication business for over thirty years, a previous poster suggested buying preflared straight lines, not a bad idea the first time.
Another thought might be some of the speed/custom shops like LMC or Jegs. for prebent lines.
Good luck.
David
Old Oct 10, 2009 | 9:31 PM
1500hd's Avatar
Try this website, classictube.com. They made a complete set from stainless steel tubing for my truck. These lines were all prebent by CNC benders and fit exactly like the OEM ones.
pwinstead
Oct 28, 2008 10:14 PM
jffgin
Sep 16, 2007 5:42 PM
jffgin
Sep 8, 2007 3:23 PM
Nomad76lj
Apr 30, 2007 10:53 PM
Trooze
Jan 24, 2006 2:02 PM
