Brake pedal grunts?? on 1500
It will be fine if I pump it a few times, but if I dont the pedal dont even want to go down. I dont know how else to describe it other way than it makes a grunting sound. Also if I go slow down a dirtroad or something after a while it will make this noise out of nowhere although not as severe
brake pedal
Could have a faulty power brake unit. With the motor off pump the pedal several times,then while holding pressure on the pedal start the engine. the pedal should go down a short way. If not the PB unit could be bad.
is the hydroboost an aftermarket product?I just got the truck a few months ago. The powersteering itself does seem to have issues at times Ill check the fluid
Hydroboost was/is used on one ton and diesel pickups.
Instead of vacuum assist, hydraulic assist from the power steering pump is used.
I see you have a 1500 so you should not have that after all.
oldtruckgoodtruck
August 21st, 2016 9:04 PM
AUChevy11
May 20th, 2013 5:25 PM
snaponbob
October 8th, 2011 5:07 PM
69rrvert
October 22nd, 2009 4:59 PM
cyptree
March 9th, 2009 11:57 AM
