Brake pedal grunts?? on 1500
Old Jan 4, 2011 | 8:26 AM
jsepps's Avatar
Default Brake pedal grunts?? on 1500
It will be fine if I pump it a few times, but if I dont the pedal dont even want to go down. I dont know how else to describe it other way than it makes a grunting sound. Also if I go slow down a dirtroad or something after a while it will make this noise out of nowhere although not as severe
Old Jan 4, 2011 | 10:16 AM
OLD WRENCH's Avatar
Default brake pedal
Could have a faulty power brake unit. With the motor off pump the pedal several times,then while holding pressure on the pedal start the engine. the pedal should go down a short way. If not the PB unit could be bad.
Old Jan 5, 2011 | 6:33 AM
jsepps's Avatar
It seems like its even worse when turning
Old Jan 5, 2011 | 2:24 PM
DoubleO7's Avatar
I can only see a relation if your truck has a hydroboost power brake system.
If yes, there maybe a problem with your power steering pump on low fuid in it, etc.
Old Jan 5, 2011 | 4:20 PM
jsepps's Avatar
is the hydroboost an aftermarket product?I just got the truck a few months ago. The powersteering itself does seem to have issues at times Ill check the fluid
Old Jan 6, 2011 | 10:47 AM
DoubleO7's Avatar
Hydroboost was/is used on one ton and diesel pickups.
Instead of vacuum assist, hydraulic assist from the power steering pump is used.
I see you have a 1500 so you should not have that after all.
Old Jan 6, 2011 | 8:14 PM
jsepps's Avatar
Im gonna take a closer look at things in a few days, Ive had the flu the past few days
oldtruckgoodtruck
Aug 21, 2016 9:04 PM
AUChevy11
May 20, 2013 5:25 PM
snaponbob
Oct 8, 2011 5:07 PM
69rrvert
Oct 22, 2009 4:59 PM
cyptree
Mar 9, 2009 11:57 AM
