Brake System- Slight Pull and pads constantly in contact with rotors
Hi, I am new here
I installed rotors and new pads on front. After driving and noticing the truck pulls to the left when braking and sometimes to the right, I took both front wheels off to have a look.
I noticed that when I would turn the rotors manually by the lug stud that the brake pads were in constant friction with the rotors on both the driver and passenger side. So the grinding noise is not noticeable while driving.
Is this normal? I thought the pads were not supposed to be in contact with the rotors when the truck was parked.
New calipers? Im confused
like said, if it was hard to turn them with the tire off then there's a problem. If they were hard, check out the calipers. The pistons could be stuck, if not, then they're fine from the sounds of it. Checked your alignment?
sounds as though i have made mistakes, if so i welcome your input, and thanks for contributing
old chevy- did not bleed brakes, thought you did not have to if you left fluid in master cylinder
cleveland63b- only when braking, and after half a turn the rotor was very difficult to turn- as if the rotor is still warped, but they were turned 20 miles ago
edac- what is PITA?
country_09- pistons depressed with clamp , but i guess they could be sticky?
have not checked alignment
spyncylce- lubed the caliper slide bolts with white lithium grease (spray can)
edac- what is PITA?
MIKE1950
July 31st, 2014 9:20 PM
19nakrahn99
December 6th, 2013 4:16 AM
Mille Racer 69
May 19th, 2012 7:27 PM
Rknow82
September 17th, 2010 12:13 AM
