Camshaft and lifters bad - Got questions
Old May 3, 2010 | 3:13 PM
  #11
LARIDERS's Avatar
most of the stuff they will re-use. But there should be a new oil pump and new water pump but they should re-use the intake, injectors, manifold. alt. and so on. not sure maybe a gm tech will have a better answer. Glad you are getting a new motor.
Old May 3, 2010 | 8:37 PM
  #12
MDTAHOE's Avatar
Professional Mechanic
New block, oil pan and pump, sometimes valve covers. Everything else transfers.
Old May 4, 2010 | 11:13 AM
  #13
tsduke's Avatar
Motor is back ordered and no eta yet.
Old May 5, 2010 | 9:01 PM
  #14
BretNasty's Avatar
last engine i got from gm had intake and all the sheet metal.
Old May 6, 2010 | 8:23 PM
  #15
tsduke's Avatar
What parts are referred to as sheet metal?
They found a motor, but said it will take at least a week. Said something about the supplier having to ship it to Michigan and then here. Is the supplier possibly a contracted manufacturer of the motor?
Old May 6, 2010 | 9:32 PM
  #16
BretNasty's Avatar
valve covers, timing cover, and oil pan
Old May 7, 2010 | 11:06 AM
  #17
tsduke's Avatar
Motor surprisingly showed up this morning already. The mgr called it a GM Goodwrench remanufactured motor.(reman-new) I didn't like hearing that, but he claims internals are all new and cylinders aren't bored or sleeved. I don't really understand why they call it reman, because they said it's not rebuilt.
Anyone have any experience with a GM reman? do I have anything to worry about?
Old May 7, 2010 | 2:30 PM
  #18
desrtrat's Avatar
it was returned back to GM as a warranty core. repaired and shipped to you..
nothing wrong with, they will do it with trans also..
Old May 7, 2010 | 9:16 PM
  #19
MDTAHOE's Avatar
Almost every replacement motor is a reman unit. At work we always use dealer engines and transmissions. They give the best warranty. Never really had a problem.
Old May 7, 2010 | 10:02 PM
  #20
tsduke's Avatar
Dealer engines? Is that different from the GM reman or the same thing?
I stopped at shop. I sure wouldn't know a reman from a new one by looking at it. Looked new to me from the outside. Valve covers, oil pan and timing cover came on this one.
