can i put a spindle lift on my silverado? pix inside.
Hi, i just bought a 1997 chevy silverado 2wd 5.0 ltr, it has a 3" body lift and 6" rcd lift pretty sure its rcd. i know nothing about trucks but really wish i did. i was wondering it would be possible to put a 3" spindle lift on my truck? maybe the rcd lift already comes with it? i dont know but i have a friend who i can get the spindle lift from. im jsut looking to get more height out of my truck. will it work? thnnks, sorry if this is the wrong section to be posting in. heres a picture- http://s173.photobucket.com/albums/w...t=truck001.jpg
RE: can i put a spindle lift on my silverado? pix inside.
[hr]P.S. Your Fab-Tech Spindle part number is #FTS-1588-7. That is for a '97 Silverado 5.0L 2WD
extended cab.
That gives you a 4' lift.
extended cab.
[hr]An89Chevy - To answer your question "why lift a 2wd". If you have ever been to Baja, and on any
of their remote beach front access roads you would know why. Lifting the front end up to get larger size tires inturn lifts the differiencials up to clear those large rocks and helps in sand washes - BUT YOU NEW THAT! Also installing rear semi-floating differiencial (limited slip) helps greatly improve traction. Now as far as true "off-roading" goes I would agree 4wd is the way to go. But I just can't see beating those $35,000 to $50,000 (and up) trucks to death.
I see alot of unecessary lifting off trucks in So Cal, and don't agree with lift for show. I need some extra clearence to get through the canyon im working in and am looking for some advice on wher to purchase proper gear and not get stuck!
PCIdiot
October 16th, 2017 3:26 PM
Rlock4227
February 19th, 2012 11:26 AM
MEParks
December 3rd, 2008 5:35 AM
Secret222
November 27th, 2007 11:42 AM
