Can I swap my 5.3 for a 6.6 Diesel?
Old Nov 15, 2007 | 3:38 PM
silverado01ls's Avatar
Default Can I swap my 5.3 for a 6.6 Diesel?
I have a 01 silverado 5.3 and i was wondering if i can actually drop a duramax 6.6, is that possible?
Old Nov 15, 2007 | 4:31 PM
ZX1100F1's Avatar
Default RE: Can I swap my 5.3 for a 6.6 Diesel?
Anything is possible but no you won't be able to make it work.
Old Nov 15, 2007 | 4:33 PM
is there anyway i could make it work..i just dont want to spend the $25k+ to buy a new truck
Old Nov 15, 2007 | 7:03 PM
MalibuMaxxSS's Avatar
welll a Dmax engine is over 13 G Canadian anyhow, figuew a major front end redo, as the weight of a Dmax is crazy.....HOWEVER GM mad a 1/2 wiht a 6.5 a few years back, there are a few kicking around so it is possible but not for a reasonable amount of $$.......
Old Nov 15, 2007 | 7:46 PM
structures282's Avatar
http://www.trucktrend.com/features/t...nes/index.html
This article is about installing a 6.6 into a 89 K1500. They actually replaced the dash for electrical reasons. Hey don't forget to add to your bill an Allison trans. Being that the 4l60e can barely handle the 5.3l, I doubt it will handle the Duramax (assuming the housing matches up). I hope this article completely turns you off to this project. Sometimes I consider myself optimistic, but my gut is telling me this is going to be an expensive undertaking on your part. But if you do decide to take on this project can I have your engine and trans for my 65 chevy? j/k
Old Nov 15, 2007 | 8:19 PM
ZX1100F1's Avatar
ORIGINAL: silverado01ls
That's why God created USED TRUCKS.
Old Nov 15, 2007 | 10:49 PM
engine2's Avatar
It would be cheaper to trade in. I saw some H2's converted to the Duramax that had a 90-100K sticker.
Old Sep 27, 2016 | 8:06 AM
Chris Buresch's Avatar
Default Duramax in Silverado
Yes it's very possible. Guy here in Florida does it to Suburban, Tahoe and Silverado. You have to change transmission, front and rear axles and lift truck minimum of 3" for clearance. Fuel tank too and other electrical and computer changes also. Going to replace my 5,3 with a 2011 6.6 duramax.
Old Sep 27, 2016 | 10:48 AM
Spencer Kitchen's Avatar
**** the 6.6 put a 6.2 detroit deisel in it
Old Sep 27, 2016 | 6:42 PM
+1 for just buying a used truck built for it.
things that don't match...the frame, trans, rad, axles, drivshaft, differentials fuel tank, multiple modules...do i need to continue
