can't get rear drum off
Old Nov 16, 2014 | 1:09 PM
dusted800's Avatar
Default can't get rear drum off
son has 2008 , 2whl drive silverado that I can't get one drum off. usually I can hit with a hammer and the vibration will loosen the drum up but this one I have pounded on for 10 minutes and it will not move. are the two holes tapped in the drum for a puller? any suggestions or tips? thanks
Old Nov 16, 2014 | 3:25 PM
crl1028's Avatar
What type if axle is it a full floater or semi floater? If it has auto adjusting brake drums then u need to loosen them and if it has ebrake make sure it set if it has cable running into it .
Old Nov 16, 2014 | 6:44 PM
dusted800's Avatar
its just a little half ton shortbed, its not the brake shoes or the emergency holding them on, they have never been off and the rust is holding them on and like I said I can usually hammer on the outside of the drum and the vibration will loosen them up. I have never used a puller on them and don't know if the two holes tapped into the face of the drum are for a puller? I am looking for some suggestions on what people have used to get them off. thanks
Old Nov 16, 2014 | 7:02 PM
Rednucleus's Avatar
How bout blast it with the rust buster of your choosing and send it to it's room for 24 hours and hit it again later
Old Nov 17, 2014 | 12:23 PM
nauticstar87's Avatar
Bit of some Aero Kroil or something along them lines, or a lil bit of heat to the face of the drum and pop with a hammer. You prolly know this, but obviously make sure the keepers are off the studs. The two holes should be for a puller, if they are tapped. Worth a try anyway. good luck to ya
Old Nov 22, 2014 | 8:41 PM
privatecarp's Avatar
loosen the adjuster on the brakes
Old Nov 22, 2014 | 8:46 PM
burhead1's Avatar
use rust penetrate, the holes should fit a 8mm bolt. be careful as you can crack the face of the drum using the bolts.
aebig
Jun 1, 2021 9:25 AM
bigrig454
Nov 25, 2019 3:25 PM
JRich_taco
Aug 31, 2013 12:16 AM
tom5170
Jun 20, 2011 4:10 PM
