chalky spots on hood
Old Jun 17, 2010 | 9:01 PM
grubbs11's Avatar
Default chalky spots on hood
i have these chalky spots on the hood of my 06 1500HD after i wash it or after it rains. i have waxed the hood several times but the chalky debris keeps coming back after a few days. the hood is very shiny and it looks like a mirror when finished.there are also some spots on the hood that i cant get off and and this is where the chalky substance appears they turn chalky on the outside of the spot. any help is appreciated
Old Jun 17, 2010 | 10:56 PM
LARIDERS's Avatar
I am not sure what that would be or make that happen. do you have a pic you could share. Might give a little better idea on whats going on.
Old Jun 18, 2010 | 6:54 AM
maxxman04's Avatar
sounds like oxidation, which wax won't remove. you need to use a rubbing compound, then a polishing compound, then wax. oxidation occurs from sitting in the weather. mainly sunlight. wax only puts a protective coating on the surface, the rubbing compound cuts thru the chalky stuff, polishing compound brings the shine back. you can use an electric orbital buffer, or by hand. Meguiar's makes some really good products, available at most auto parts stores.
watson 29
May 28, 2008 7:05 PM
ez1putt
Oct 15, 2007 7:09 PM
ironcy
Jul 21, 2007 9:29 PM
kamikaze124
Jun 17, 2007 6:43 PM
