Check engine light on 08 Silverado
Old Dec 24, 2010 | 11:31 AM
nthomas's Avatar
Default Check engine light on 08 Silverado
I have an 08 Silverado 1500 with a 5.3L. I put a K&N cold air intake on it and about an hour after driving it the check engine light came on. I am now getting a code that says "system too lean bank 1,2,3 and 4". I put the factory intake back on thinking it would fix it, but the light came back on... Does anyone know what is causing this?
Old Dec 24, 2010 | 6:00 PM
crwalker2's Avatar
You made sure to hook up the MAP sensor didn't you? Not sure what else would cause something like that, I have the K&N cold air intake on mine. I unhooked it once while it was running to check something on the throttle body and it killed the truck and I also got a light. I just unhooked the battery, then hooked the battery back up and everything went away.
Old Jan 1, 2011 | 12:07 PM
CJ_Tiz's Avatar
Could be a couple of things. Oil sucked off the K&N and is now coating the MAF sensor. Fix is use less oil and get some MAF cleaner and clean it a couple of times. I don't know about the 08 models but i know with my 04 6.0 I got myself a tune to have the MAF sensor read the more air it was pushing thru. I also run a K&N. Hope this helps
redrotor
Cobalt
Aug 29, 2019 8:38 PM
o.valdez
Dec 17, 2011 10:46 PM
psd7.3
Dec 22, 2010 8:23 PM
101btp
Nov 30, 2010 8:36 PM
93chevyman
Mar 12, 2010 1:13 PM
