Old Aug 11, 2015, 1:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
check engine light
Old Jul 1, 2008 | 1:02 PM
jamesdal7's Avatar
Default check engine light
OK, I'm in a little bind. I have a 2004 Silverado, 5.3 V8, Z71 truck, my check engine light turned on, I had the code checked and I need to replace my knock sensors. I have to take the intake manifold off to get to the knock sensor. About 4 hours of labor, The problem is, I'm moving and staying at an apartment and don’t have all my tools and stuff to do it myself, PLUS i have to work during the day, 10 hours.I have to get my inspection done today or tomorrow the latest. I'm in Dallas,TX so you can't have the check engine light on during the inspection.
I disconnected the negative battery cable for about 30 minutes and the light stays off for about two hours, then it comes on. So my question is,if I go in with the check engine light off, will it show up during the inspection? I just need time to replace knock sensor but need my inspection done today, any one have experience on this?
Old Jul 1, 2008 | 3:08 PM
ehhget's Avatar
Default RE: check engine light
I think you will be ok as long as the light stays off. The inspection station takes all your results from your trucks computer so if no light is on then it should not be sending a problem code.
Old Jul 1, 2008 | 11:40 PM
jamesdal7's Avatar
ok, i went in and they told me i need 2 oxygen (O2) sensors replaced. I replaced two, but i just want to make sure i replaced the right one, I got the following codes:
P0161: O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0141: O2 Sensor Heater Circuit Malfunction (Bank1 Sensor 2)
Is it it referrering to the POST sendors? The ones AFTER the catalyst? The Haynes book refers to it as the POST sensor. I just need to make sure, I'm going back in the morning and need to make sure I replaced the right ones.
Old Jul 2, 2008 | 6:39 AM
jmack91z28's Avatar
Yes, your correct. Sensor 2's are post catalytic or "downstream".
I guess it's too late to help you, but I'm pretty sure you can unplug the ecm fuse for a few minutes then plug it back up before you go in and it'll clear all your codes out.
Old Jul 2, 2008 | 7:25 AM
jamesdal7's Avatar
Thanks jmack, I will unplug the ecm fuse for a few minutesbefore I take it in again.
Old Jul 2, 2008 | 2:11 PM
jamesdal7's Avatar
One other thing someone told to me check was theo2b fuse,this controls the heaters for those 2 sensors. Sure enough it was blown, I replaced it and light turn off. So, if you have an oxygen sensor out, more likely the fuse will be too.
redrotor
Cobalt
Aug 29, 2019 8:38 PM
o.valdez
Dec 17, 2011 10:46 PM
psd7.3
Dec 22, 2010 8:23 PM
101btp
Nov 30, 2010 8:36 PM
93chevyman
Mar 12, 2010 1:13 PM
