Check engine light 1999 Silverado
I just recently had my fuel pump replaced(three weeks ago) and my check engine light came on. I pulled the code and it is a PO453 Evap Cntrl System Pressure sensor High. Now is the sensor bad or is the pressure to high? If its the pressure what would be the likely culpret? I know its a no no to top of the tank but i did it 4 days before this happened but ive done that on many occasions in the past ten years. I know a bad gas cap would be low pressure leak but could it pertain to this also? Could it be something the garage did? They also had to make a fuel line from the filter to the tank because the old one was to rotted. I can only see a small portion of this but it looks like they did a good bending job and told me they had the right flare for it.(no pun intended) Any Thoughts would be greatly appreciated. IM still reeling from the fuel pump bill!
o.valdez
December 17th, 2011 10:46 PM
