Check Engine Light
Old Jan 29, 2007 | 4:03 PM
hoytheld's Avatar
Default Check Engine Light
I can get it to go off with a battery discconect, but after a short time it comes back on. Is it on because the truck has aftermarket dual exhaust? What is a remedy?
1999 new body z71 4x4 3 door 120,000
Old Jan 29, 2007 | 8:48 PM
golfer's Avatar
Default RE: Check Engine Light
What's the problem code ??
Did thid happen right after putting on the aftermarket exhaust ??
Did you include the O2 sensor ??
Old Jan 30, 2007 | 7:03 PM
hoytheld's Avatar
Golfer,
Bought it with the exhaust on it...don't know code or O2 sensor? Should I see what the code is first?
Jason
Old Jan 31, 2007 | 1:27 AM
golfer's Avatar
ORIGINAL: hoytheld
Golfer,
Jason
Yes.
Old Feb 2, 2007 | 2:21 AM
kcb37's Avatar
Look at the exhaust. If you still have the factory cat and a electrical sensor (o2) behind each one. I am assuming you had dual to the muffler factory.
If you have a cat back exhaust you should be fine. Take it to Auto Zone or Advance Auto Parts they will check it for free. If it says it is lean or rich check the o2's but keep in mind a rich burn can mean a bad plug not getting a full burn or lean can be from a dirty fuel filter.
redrotor
Cobalt
Aug 29, 2019 8:38 PM
o.valdez
Dec 17, 2011 10:46 PM
psd7.3
Dec 22, 2010 8:23 PM
101btp
Nov 30, 2010 8:36 PM
93chevyman
Mar 12, 2010 1:13 PM
