check gauges light wont cut off
my 96 1500 has had the check gauges light on since i bought it 3 months ago.my buddy hooked up his scanner tool and everything came back good. I have good oil pressure plenty of gas, a brand new battery, and its not overheating what else could i be missing that would cause this light to stay on. Its been driving me crazy trying to figure this out. any feedback would be appreciated.
![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
Well there weren't any codes. It's not the same as the 'check engine light its another one that says check gauges' light that won't turn off. I heard it turns on if you're low on gas, overheating, etc
ok, so all the gauges appear to be reading normal and good? low voltage reading, high temp, low or no oil pressure. these all will set off the check gauge. it supposed to go out when all is well. if it's not, and all is good, you may want a shop to look at. might be ecm issue.
I just rechecked everything again and still good. And I just replaced the ecm a month ago for different reason but that light is still on my buddy suggested trying a thicker oil what do yall think
my99suburban
April 9th, 2014 7:47 PM
o.valdez
December 17th, 2011 10:46 PM
