Chevrolet 350 question?
Old Apr 4, 2008 | 4:49 PM
jjett84724's Avatar
Default Chevrolet 350 question?
Hi guys,
I am new to the forum and have a question for the guys who know what they are talking about. I have a 1987 GMC Sierra with a 5.7 (350) motor. The motor is Throttle Body Injected. I was driving home with the wife and baby and the truck got hot. I found water in the oil and thought it might be the head gasket. I tore the engine apart and found coolant in #3 and #5 holes. I replaced the head gaskets and fired the truck back up and immediatley found water in the oil again. I believe the engine is toast. [:'(]
I have checked around for a few boneyard motors. One guy is telling me that any year 350 will work as long as I bolt my heads on it. I am not so sure. So, I am asking the forum for your help. Thanks in advance.
Jesse
Old Apr 4, 2008 | 7:59 PM
estraw's Avatar
Default RE: Chevrolet 350 question?
did you check your heads and block deck for flatness? it could be warped and allowing water to enter the cylinders
Old Apr 5, 2008 | 4:09 AM
jjett84724's Avatar
I did not check the head or the block to see if they were warped. I am going to change the engine out regardless. It had been using some oil. Might as well fix it right. I am still hoping for a reply about my earlier question. Will my cylinder heads fit on an older 350?
Old Apr 12, 2008 | 6:48 PM
old dog's Avatar
i would not mix and match the 305 heads uses a light weight casting design (they love to crack ) if you can find a good 1970-1977 use the whole thing,your heads are prob cracked .
5.0stang
Jun 16, 2022 7:46 AM
computerdude14
Jan 8, 2013 3:33 PM
shawnmid
Aug 4, 2010 1:19 AM
shawnmid
May 22, 2009 7:29 AM
