Ck1500 engine problems need help
Old Dec 16, 2009 | 1:22 PM
AdamSaint's Avatar
Default Ck1500 engine problems need help
ok i have a '90 C1500 automatic and the engine was (shot) so i got found a '92 ck1500 with a standard and did an engine swap. i assumed the engines were the same but maybe i was wrong. ever since i dropped it in its been running rough. at idle it idles down low then it sounds like it revs up some then does it again that only happens in park not in gear or neutral. when driving it runs fine except at a certain rpm it sounds like its missing. i cant figure out the reason. any help or suggestions will be appreciated.
Old Dec 16, 2009 | 7:00 PM
mudmaniac's Avatar
Ride of the Month
May 2009
Did you re-use most of the bolt on stuff like the throttle body and distributor, or are they from the donor truck?
Old Dec 16, 2009 | 11:10 PM
Speedy650's Avatar
timing?
Old Dec 17, 2009 | 10:55 PM
AdamSaint's Avatar
the distributor was reused from the original engine but not the carb. tried swapping the distributor and carb with no change. timing is correct (i think).
more info: the problem with missing only happens when it warms up
Old Dec 18, 2009 | 7:38 AM
mudmaniac's Avatar
Ride of the Month
May 2009
That would tell me it is an issue with the electronics, it will run open loop untill the truck warms up.
Old Dec 18, 2009 | 12:11 PM
AdamSaint's Avatar
i had hoped it wasnt an electronic problem because i dont think i can fix it
could it be a single broken sensor?
Old Dec 19, 2009 | 5:42 AM
mudmaniac's Avatar
Ride of the Month
May 2009
I had a similar problem that was caused by a faulty connector on the temp sensor located at the manifold gooseneck. Mine would cause the SES light to come on.
Old Dec 19, 2009 | 10:45 AM
AdamSaint's Avatar
yeah i smashed the exhaust temp sensor when stabbing the engine in and the ses light is on but i wanted another opinion before paying for a new one. ill replace it and see if it helps.
Old Dec 19, 2009 | 3:33 PM
mudmaniac's Avatar
Ride of the Month
May 2009
That should take care of the problem.
Old Mar 2, 2010 | 3:03 AM
f-bodyfreak's Avatar
iv done lots of swaps and iv seen many times that the ecm from the doner car should be used most of all when dealing with diffrent years
chilliwapo
Jan 16, 2010 2:41 PM
chilliwapo
Dec 29, 2009 9:09 PM
KMaguire
Oct 11, 2007 5:14 PM
bcolvin58
Oct 1, 2007 3:44 PM
aninias
Mar 21, 2007 7:17 PM
