Old Aug 10, 2015, 12:07 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
Clock radio stays on and drains battery
Old Sep 11, 2010 | 1:08 PM
jay8397's Avatar
Default Clock radio stays on and drains battery
I just bought a 1998 c1500. when i start the truck i noticed that my clock would reset and i would loose all my presets. so i check the fuse panel and noticed that there was no 10amp fuse in the radio fuse bay. i thought ok easy! put a 10amp fuse in and everything was ok, but i noticed that the clock would stay illuminated on the radio when the truck was shut off. i didnt think anything of it, thinking that its only 10amps and would not drain the battery. woke up the next morning and dead as a door nail. anybody have any thoughts?
Old Sep 11, 2010 | 2:01 PM
Mille Racer 69's Avatar
Well 1st off it sounds like the remote wire.
The remote wire tells the deck to turn on/off.
quite a few DIY'rs attempt to install car stereos and do the install wrong.
It has been a while since I have done them, but I think generally the
blue wire with the green stripe is the remote wire. The yellow wire is your
power source, be very careful of that wire. If it grounds out, ALL of your
electrical system in the truck could get fried.
Although it gets a bit more complicated if you have onstar.
Is the truck onstar equiped? If no, don't worry about it, your problem is that the
remote wire is not hooked up properly. If you take it to Fry's, Best Buy, or some
car audio place they can wire everything correctly for $40 - $50 which is
what I suggest you do because the DIY installer coulda done a poor job at connecting
the install kit wires, coulda left exposed wires, and it could be a mess behind there.
Old Sep 11, 2010 | 2:55 PM
jay8397's Avatar
this is a stock radio, so its never been removed.
Old Feb 20, 2018 | 6:05 PM
Mark Allen Chastain's Avatar
I'm having the same problem with a 1996 2500. Drains the @#%$ out of a battery. Usually takes a few days on a good battery though, you may want to check the battery.
To be more specific, and avoid going down rabbit holes...
The Radio does not stay on, JUST the clock. I see people going on about the ignition switch, but I don't think that could be it. That woudl keep the radio on, not just the clock
The 10 amp fuse you pulled was for the BAT supply, not just radio.
There is only one way this can happen - Radio is broken or incompatible.
Based on the 96 schematic there are only three power inputs to the radio. IGN, BAT, and DIM. The clock should only come on if the IGN power is applied.
Try swapping it for one you know comes from a basic, 1996 - 98 truck, no amp, not from an SUV, etc... Od just replace it with an aftermarket.
LETSFIXIT
Feb 15, 2014 1:35 PM
irishliz
Oct 16, 2012 2:04 PM
jay8397
Jul 26, 2011 10:20 PM
Igotasilveradonstuff
Dec 8, 2010 12:55 PM
Kershiv
Oct 10, 2010 11:58 AM
