Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX Why Won't Clock Turn Off
Guide to diagnose trouble and recommended solutions.
Clock won't turn off
My '99 Silverado clock stays on after I've shut the key off - I've been ignoring this for a while, but now one of the daylight running lights quit working, but it isn't the bulb and I'm hoping someone can suggest how to troubleshoot or fix both of these issues.
I noticed the clock quirk after the battery died and I replaced it. Now the clock stays on all the time and I can only go 3 days without starting and running the engine or it drains the battery.
I followed the manual's directions to toggle between having the clock displayed or off, but it has no effect either way - it never turns off...
Any suggestions are appreciated.
ROTM Coordinator
ROTM Coordinator
Kinda sounds like there was a power surge that may of fugged up a computer or module that controls certian things. Have you disconnected the battery for 15 min or so to completely reset the ECM's? Other than that, got me. My running lights quit on me a few years ago and its not the bulbs, but I could care less about those, everything else works fine.
Maybe another member can shed better light on this one.
The radio is contained solely in the radio and has nothing to do with the computer system.
Disconnect the battery for several minutes and reconnect.
Alternatively, pull the fuses for the radio.
If that doesn't fix it, I pass the torch to another tech
As for the DRL problem, You probably have a headlight fuse blown or a connection issue.
Be sure the rod connector between the ignition lock cylinder and the ignition switch(about 18" lower on the column) is properly adjusted and tight. When you turn it off recently, do you have to turn the ignition key further than normal to get it out of the lock?
Although I've had no issues with the key and the radio itself shuts off normally, this will be next - I haven't had time to look into this yet.
I'm with rivereye on this. I would look into the ignition cylinder/switch. If it were a fuse you would have no door chime and the clock wouldn't even be illuminated. The chime fuse also is for the clock on the radio. The fog lights are probably another operation all in themselves. I would look into the fuse/relay for the fog lights as a starting point. It would be very inconvenient for both to go out at the same time unless you didn't notice one go out first.
Classifieds Moderator
TruckForums Liaison
TruckForums Liaison
I fixed an engine noise, wind noise, brake noise, and tailgate noise with one thing and one thing only... WD-40!
Spray some of that everywhere
Another option for the lights would be some good old fashioned blinker fluid: http://kalecoauto.com/index.php?main...&products_id=6
Cburdett
April 8th, 2014 11:01 AM
clhg007
Avalanche
April 4th, 2013 9:13 PM
Mr. Vann
November 25th, 2009 7:24 PM
TriVHo
February 18th, 2008 4:14 PM
