Cluster mini gauges and ac stop working together
Old Jul 18, 2023 | 10:41 PM
KD_23's Avatar
Default Cluster mini gauges and ac stop working together
Just picked up a 2002 2500HD with 6.0 v8. All at the same Time the PRNDL on the cluster goes out, trans temp gauge, engine temp gauge, oil pressure gauge, fuel gauge and battery voltage gauge freeze. The ac stops blowing, the dome lights stop working and the power mirrors stop working. The speed and Rpm gauges both work while this is going on though, just the mini gauges freeze where they were before the problem starts. Battery light comes on when all this happens.. The battery was tested and it was fine. Is there a fuse / relay I should look at, could the alternator be going out?
Old Jul 19, 2023 | 9:16 AM
KD_23's Avatar
Battery being disconnected and reconnected seems to fix the issue for a little bit.
Old Jul 20, 2023 | 11:02 AM
KD_23's Avatar
Update: I think its two issues.
Typical cluster issues on these earlier silverados.
For the ac I am getting 12V to blower resistor but not to the blower motor. New resistor same thing, new ac control module still no luck. It seems like im getting some power to some of the ac system.
It seems like im not getting power to the ac control module becasue the lights on it dont come on either. I hooked up a scanner and found it was throwing false codes that arent related to anything. Im thinking it could be a bad ECM now, any input would be great.
Old Jul 20, 2023 | 4:57 PM
check all fuses and grounds
Old Jul 21, 2023 | 3:09 PM
KD_23's Avatar
I gave up and took it into a reputable auto electrcian, will update on what he finds!
Old Jul 27, 2023 | 11:43 AM
KD_23's Avatar
Got the truck back Monday, the shop found a connector in the steering column with a bent pin. He replaced that connector and it solved all the electrical issues!
Old Jul 27, 2023 | 4:25 PM
that was quick. Hang on to this mechanic. They're hard to find.
Care to drop a referral?
Old Jul 27, 2023 | 6:22 PM
KD_23's Avatar
Yes no problem.. Its "oz mechanics" in Houston Texas. He actually has a Youtube channel with almost 100k subs, check him out.
wscottman
Oct 27, 2017 12:50 PM
bigge31566
Aug 13, 2013 1:10 PM
mvusse
Oct 1, 2012 7:01 PM
Bushrat
Jan 26, 2012 3:08 PM
willie1155
May 17, 2009 10:28 PM
