Clutch Help! '95 Chevy C1500 5 SPD
I Have bought Two master cylinders now, the original one that i had on the truck broke off the push-rod bushing, replaced the bushing and then not even two hours later broke the rod, replaced the master altogether. After replacing I bled the system the old fashion way for a good 4 hours
The next day i went out and replaced the slave thinking it might be the slave cylinder. Bled it through the old fashion way for almost 9 hours to no avail, broke the master cylinder push-rod again
Replaced the master with a higher quality one today and bled it through the old fashion way again for about 2 hours to no avail and this time no pressure so i went in and looked up different ways of bleeding a hydraulic clutch found one i liked better than breaking another push-rod,
gravity bleeding. Tried it for about another hour, checked the pressure and i could not move the pedal,
At All. So again i tried to bleed it the old fashion way and my pedal became stuck half-way through pedal movement. I looked and yet again another push-rod needs replacing
. Any ideas what the problem could be?
Tight on money with a baby on the way. Pictures are: Original broke in 3 pieces, second broke in 2 pieces, last one bent. PLEASE HELP!!!
![EEK!](https://chevroletforum.com/forum/images/smilies/eek.gif)
![Mad](https://chevroletforum.com/forum/images/smilies/mad.gif)
![Smile](https://chevroletforum.com/forum/images/smilies/smile.gif)
![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
![Angry](https://chevroletforum.com/forum/images/smilies/angry_smile.gif)
rhinoman7
October 4th, 2019 8:39 PM
Jenny White
1988 - 1998 (GMT400)
September 6th, 2016 4:25 AM
