Clutch Help! '95 Chevy C1500 5 SPD
Old Jan 15, 2015 | 2:28 AM
Dhmarkjr2's Avatar
Default Clutch Help! '95 Chevy C1500 5 SPD
I Have bought Two master cylinders now, the original one that i had on the truck broke off the push-rod bushing, replaced the bushing and then not even two hours later broke the rod, replaced the master altogether. After replacing I bled the system the old fashion way for a good 4 hours The next day i went out and replaced the slave thinking it might be the slave cylinder. Bled it through the old fashion way for almost 9 hours to no avail, broke the master cylinder push-rod again Replaced the master with a higher quality one today and bled it through the old fashion way again for about 2 hours to no avail and this time no pressure so i went in and looked up different ways of bleeding a hydraulic clutch found one i liked better than breaking another push-rod, gravity bleeding. Tried it for about another hour, checked the pressure and i could not move the pedal, At All. So again i tried to bleed it the old fashion way and my pedal became stuck half-way through pedal movement. I looked and yet again another push-rod needs replacing . Any ideas what the problem could be? Tight on money with a baby on the way. Pictures are: Original broke in 3 pieces, second broke in 2 pieces, last one bent. PLEASE HELP!!!
Attached Thumbnails Clutch Help! '95 Chevy C1500 5 SPD-truck-part1.jpg   Clutch Help! '95 Chevy C1500 5 SPD-truck-part2.jpg   Clutch Help! '95 Chevy C1500 5 SPD-truck-part4.jpg
Old Jan 7, 2020 | 9:11 PM
troutstock's Avatar
I know this is a really old post, but did you ever solve this problem?
Old Sep 29, 2021 | 6:49 PM
Jimmy Brideau's Avatar
Unhappy
sounds to me it was something to do with clutch fork....I had similar problem and it was fork worn thru at the pivot ball
FriedChicken 1
1988 - 1998 (GMT400)
14
Dec 20, 2019 10:02 PM
Jenny White
Sep 6, 2016 4:25 AM
Kaosminis
Oct 20, 2013 9:00 PM
Menissalt
Aug 12, 2009 7:06 PM
