Clutch Master
I have a 1996 c1500 4.3L & 5spd. I started having problems shifting from 1st to 2nd and would have to turn off the truck just to put it in reverse. I started looking at the fluid level in the clutch master slave cylinder. It was a little low but I also found the fluid was black and little thicker than normal. Black to me shows the fluid got very hot at some point. I first had a friend pump and hold the pedal then I opened the bleeder on the clutch slave cylinder and some fluid cam out and it was black but there wasn’t a great amount. So I topped of the master slave cylinder and the pedal stays the floor with no pressure. So I removed clutch fluid line from the master slave and blew air through the line and a little more black fluid came out. I reconnected the line to the master slave and with the bowl filled and the clutch line open no fluid came out. So does anybody have any suggestions???
