Cold Start Problem
Old Mar 2, 2009 | 9:23 AM
fijidaniel's Avatar
Default Cold Start Problem
So the 03 Silverado has had some problems starting cold. I replaced the fuel filter, cleaned the air filter, and replaced the spark plugs. The engine runs fine and I've had no lack of performance or any troubles with warm starts. It only gives me grief with the cold starts and usually fires up on the first (with strain) or second time. Any ideas on what to try next?
Thanks!
Old Mar 3, 2009 | 11:25 AM
therewolf's Avatar
My guess is it's the original battery? Hey no sin, they work well for a long time. Then age and cable corrosion kicks in, and viola.
I didn't want to overreact when I changed my battery, by going overboard, so I got the biggest, highest rated, longest lasting gel-cell and the strongest warranty from one of the most popular parts stores around. I just hay-hay-hate getting stuck with a dead battery.
Most large parts stores will test your battery for free. Cables are @20$ and DIY.
Old Mar 23, 2009 | 12:02 AM
carlosgv1's Avatar
check battery terminals take out bolts and check if have sulfate (salt) on the washer conector on 2 sides , clean w/ 2 tables spoon baking soda and 1 cup of hot water.
Check if it's clean the Throttle Position Sensor.
Supertwins
Jul 4, 2011 11:39 AM
Mille Racer 69
17
Nov 7, 2010 4:19 PM
2009Sierra
Nov 11, 2009 6:15 PM
Thermool
Jun 20, 2009 6:41 PM
izod
Feb 14, 2009 2:42 PM
