condensation from muffler
you guys get much moisture from the tailpipe and or out of the little wheep hole on the muffler
i live in AZ dry climate but get a puddle from the muffler some times
06 silverado 5.3
06 silverado 5.3
Hi desert chevy,
Welcome to the Chevy Forums.
I've always wondered about this, sometimes I do, sometimes I don't.
I've never been able to determine a cause/effect relationship as far as driving type,distance, weather, etc.
Humidity % in the air probably determines if condensation comes out the exhaust. Ambient air temp. is probably part of the equation also. High humidity + cool air temp = condensation. Warm moist exhaust hits the cooler exhaust system = condensation coming out the of the system. Short trips do not allow the system to heat up enough to burn the condensation out completly.
A small amount of the product of gasoline combustion is water along with all different types of carbons and oxides.
Gasoline has a little bit of water in it and it may not fully escape the exhaust.
Its perfectly normal to see moisture in your exhaust even in the dryest of climates.
Mustang72fan
January 9th, 2013 2:15 PM
clocker1617
November 29th, 2006 1:51 AM
