Dash lights
Old May 29, 2012 | 11:15 AM
gbecasfsim's Avatar
Default Dash lights
Having problem with dash lights. When i go to turn on the exterior lights usig headlight switch my radio illumination goes out but the radio still works. But my dash lights do not work. The door panel switches light up but not the dash. Could this be a bad headlight switch?
Greg
Old May 29, 2012 | 12:51 PM
johntaps's Avatar
Former Sponsor
Post Dash lights
Sound like a bad fuse. It might be located on the driver side, panel that opens on the dash board side. If you have a manual for your vehicle, there should be a section in the back for fuse diagram.
Old May 29, 2012 | 1:12 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> gbecasfsim,
I would like to look into this issue further. Would you please PM me the last 8-digits of your VIN number so I may proceed?
Louis
GM Customer Service
hzlq57
Jun 7, 2016 2:06 AM
devolic
May 18, 2012 9:04 PM
crapalier
Dec 18, 2011 5:34 AM
TxFire
Jan 10, 2011 10:29 AM
Big_Jazzer
Feb 27, 2009 1:25 PM
