Daytime running lights
Old Dec 29, 2006 | 10:17 PM
irishflies's Avatar
Default Daytime running lights
My lights do not come on any more when I start my 1996 1500 305 4#4. The indicator light on the dash is on. Any clue?
Old Dec 30, 2006 | 12:27 PM
golfer's Avatar
Default RE: Daytime running lights
Doesyour vehicleuse the headlights for DRL ?
For example on my 00 Express van the DRL were the high beams on reduced current. You could in that case check to see if the high beams work as well... they may be burned out.
I had problems with the DRL on my van and turned out to be the module.
Old Jan 8, 2007 | 11:08 PM
Riccas's Avatar
These lights are very suseptable to vibration and an a/c current. These bulbs burn out all the time. I've always had GM's and trade them every year, i don't think i've ever traded a vehicle with working DRL's
Old Jan 9, 2007 | 10:56 AM
golfer's Avatar
ORIGINAL: Riccas
a/c current from where ????
Lamps will work on A/C or D/C it doesn't matter which. If you take an automotive bulb hooked up to 12 v A/C it will work just fine.
RitualJman
15
Apr 22, 2026 9:15 PM
LTZ_HOE
Jul 5, 2025 7:00 PM
peacekeeper
Mar 17, 2010 2:00 PM
stingray502
Oct 25, 2006 12:31 PM
