Diesel sound with a 350
Old May 13, 2012 | 11:19 PM
Harvey70's Avatar
Default Diesel sound with a 350
Hi my name is Tyler, i drive a 1988 K2500 P/U. I've got a 5.7L 350 i just bought as a crate motor last year. it came stock as a Throttle Body Injection (TBI) i just recently Carburated it with an Edlebrock 750. after tearing the heads off of it and cleaning em up. i just got it running the again yesterday and after getting everything figured out, it knocks when the motor is under touqe or when i just punch the throttle from idle in short burst, and also around 2500 to 3500 rpm. its not exactly a knock it sounds like a diesel, when it makes this noise. its not timed perfect but its as close as i can get it by ear with out a timing light because of the MSD Distributor. any idea on what it could be would be greatly appreciated.
Old May 14, 2012 | 11:25 AM
EinST's Avatar
Welcome to the forum. Are you talking about spark knock? The list of suspects include too much ignition advance (knock sensor inoperative?), too high a cylinder compression ratio, low octane fuel, etc.
Old May 14, 2012 | 11:59 AM
therewolf's Avatar
Hi Harvey70,
Welcome to the Chevy Forums.
I moved your thread to the proper section.
Why don't you read the rules, and re-post in the
"Welcome" section?
Old May 14, 2012 | 8:15 PM
RacerX's Avatar
Hmmm, I drove a 454 one time where it sounded similar. Apparently the sound was that of the fuel injection system. It would only do that under load and it sounded like a diesel rattle but it was the fuel injectors making all that noise. I dont know if it is bad or not.
Old May 15, 2012 | 9:03 PM
FunkMasterTD's Avatar
retard the timing some more, try again, or get a darn timing light
but pretty sure its to advanced
Old May 16, 2012 | 8:07 AM
Harvey70's Avatar
Default thanks
Thanks therewolf I didn't know what to do. It was the timing to advance I finally broke down and invested in a timing light, thanks every one
jeffcool
May 16, 2015 6:48 PM
jsncrss94
May 26, 2014 12:47 PM
Marcus Worth
Cruze
Jul 31, 2013 2:31 PM
atm0001
Jul 13, 2007 1:34 AM
