diff oils front and rear
Old Apr 19, 2008 | 4:40 PM
petrou's Avatar
Default diff oils front and rear
my 02 2500 hd takes syn 75-90 in the rear diff, for the front it takes 80-90 non synthetic, can i or has anyone pt synthetic in the front diff, also do i need any additive for the limited slip.
Old Apr 19, 2008 | 9:40 PM
ehhget's Avatar
Default RE: diff oils front and rear
You should check with Royal Purple. They are really good about answering questions like that via email.
Old Apr 20, 2008 | 6:08 PM
petrou's Avatar
thank you ill give them a hollar
Old Apr 21, 2008 | 1:12 PM
rjsasaoka's Avatar
I just put in Royal Purple this weekend in the Rear Diff. I've been hearing a lot of good things about them and decided to pick up some. The nice thing about it is that it doesn't smell like the other stuff. Most of the other stuff stinks after a while.
Old Apr 21, 2008 | 11:08 PM
ehhget's Avatar
Yup Im running out my stock of Penzoil then Im going to RP on all my fluids. If you go to this link and enter the word closeout on the coupon you can get a sweet deal.
http://www.partsamerica.com/default.aspx
Old Apr 22, 2008 | 10:18 AM
ZX1100F1's Avatar
You can use synthetic gear lube in the front diff just make sure to use the correct weight.
No need for any additive since the GM rear-ends are not limited-slip, if you have the G80 options it is an Eaton auto-locker and it requires no additive since there are no clutch packs.
sgt
May 21, 2013 11:35 PM
Rob G
Sep 16, 2011 9:50 AM
jims05chevy
Aug 20, 2011 7:58 AM
2500HD_Dan
Dec 15, 2007 11:53 PM
Faith_plus_1
Mar 2, 2007 3:17 PM
