Old Aug 11, 2015, 1:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: General Overview
Print Wikipost
Differential VIN codes
Old Apr 26, 2010 | 6:05 PM
smitty65534's Avatar
Default Differential VIN codes
I am trying to determine which differential is in my 2007 2500HD. This is a 2wd (I really think it is a one wheel drive). Local Chevy dealer says it is a limited slip but I am sure it isn"t. VIN is 1GCHC29697EXXXXXX.
Old Apr 26, 2010 | 6:53 PM
nauticstar87's Avatar
Look in the glove box. There should be a list of RPO codes. Prolly start with a G. Mine is GT5 for 4.10s. G80 would mean you have posi.
I used to be able light up both rear tires on my 07 2500HD, it's getting more and more difficult to do on pavement.
Old Apr 26, 2010 | 8:02 PM
I've checked the codes in the glove box. There is a "GMC" & "GT4." The ratio is 3:73 (all diesels have this ratio). With 430hp, it will lite up "one" tire forever. I am guessing that the "GT4" is the actual rear end. It is a 14 bolt unit.
Old Apr 26, 2010 | 8:08 PM
14bolt is the actual rearend, GT4 is just the gears it happens to have. I can light up one wheel all day, I used to be able to light up both forever. Wish I had me a Dmax.
Old Apr 26, 2010 | 8:16 PM
Is there anyway to determine (using the build codes) if this is a limited slip or one wheel drive unit? I know what the bolt pattern is (14 bolt) and the ratio. If the unit is supposed to be a limited slip and is not functioning properly, I can have Chevy replace it. If it is actually built as a one wheel drive, I am going to have to replace the guts with an after market posi (I'm getting tired of getting stuck on wet grass).
Update: I've found the information. All RPO codes are listed at "www.rpocodes.com".
Many thanks for all the help. According to my build codes, I do not have a limited slip. I guess its time to buy the after market kit. Thanks again - Smitty
wolffullmoon
Mar 22, 2023 9:10 PM
LS1Tahoe
Feb 16, 2015 5:15 PM
CrewCabFan
Aug 12, 2014 8:29 AM
scba3diver
Mar 3, 2012 6:59 PM
cam3439
Jan 14, 2010 12:14 PM
