do i need to replace cam bearings? pics
Old Feb 12, 2012 | 11:17 PM
brady1604's Avatar
Default do i need to replace cam bearings? pics
here's my old cam from a 95 z71 with a 305cid do i need to replace cam bearings? i still have the block in the truck and i dont want to have to pull it out to do an entire rebuild. i'm just rebuilding the upper end. had a blown head gasket and valve guides were worn out so i sent the heads to get re worked and i figured i'd just rebuild the valve train. i got an rv cam to put in it but i dont know if i should install on the existing cam bearings. what do you guys think?
the pics are from cam gear going towards back of motor.
thanks for your help!
Attached Thumbnails do i need to replace cam bearings? pics-100_0197-1024x768-.jpg   do i need to replace cam bearings? pics-100_0200-1024x768-.jpg   do i need to replace cam bearings? pics-100_0201-1024x768-.jpg   do i need to replace cam bearings? pics-100_0203-1024x768-.jpg   do i need to replace cam bearings? pics-100_0204-1024x768-.jpg
Old Feb 13, 2012 | 7:40 AM
Allan In NE's Avatar
Naw, cam bearings are okay.
<O</OHOWEVER, if this is a high mileage engine (250-300K), I'd sure roll under 'er and throw in a set of inserts tho.
<O</OTightening up the top end on a somewhat "tired" engine really puts a lot of strain on those lower bearings and does hasten their demise.
<O</OAllan<O</O<O</O
RacerX
Feb 24, 2019 7:59 PM
Dowd_Elwood_P
Aug 9, 2015 4:53 PM
little
Aug 26, 2007 2:34 PM
roman316
Dec 18, 2006 3:15 AM
HeyDace
May 14, 2006 8:48 AM
