Dome light won't come on when opening passenger door
I have a 2008 Silverado Crew Cab and the dome / courtesy lights come on for all doors except the front passenger door. I suspect it may be a wire or a fuse but all the other power options for that door are working. Anyone have an idea?
you may be right.
if pushing the dash dome over-ride does not fix it you may need a new lock actuator. I would have someone with a scan tool view the door switch input data to the bcm. Usually, they provide a grd signal to the bcm, so if grding the wire changes the signal at the bcm...you need an actuator.
gneville
Uplander
10
September 24th, 2023 12:36 AM
highlander
June 22nd, 2021 11:21 AM
gneville
Uplander
October 17th, 2014 7:21 PM
