Dome Light Won't Turn Off
Old Oct 26, 2006 | 11:00 AM
bern10's Avatar
Default Dome Light Won't Turn Off
I did a quick search and couldn't find anything.
I have a 99 Silverado Z71 and my dome light, nor the left and right floor panel lights will go out. The dome over-ride button will not turn them off either.
I had to disconnect the battery. Once re-connected, they came back on.
Any help would be greatly appreciated.
Thanks,
Bernard
Old Oct 26, 2006 | 1:28 PM
lost_in_alabama's Avatar
Default RE: Dome Light Won't Turn Off
Be sure that the dash light dimmer switch, located on the headlight switch assembly, that controls the dash light brightness is not all the way up. If that's not the problem, then I suspect that the headlight switch assembly needs replacing.
Old Oct 26, 2006 | 2:49 PM
bern10's Avatar
I will take a look at those 2 options. If no cure, I have to pass a dealership on the way home and will ask this question there. (Hopefully a free answer can be acquired) Thanks!
Old Oct 27, 2006 | 11:51 AM
bern10's Avatar
Thanks lost_in_alabama,
I did have the dash light dimmer switch all the way up. Made the adjustment and all is well.
Thanks also to this website that connects Chevy questions to answers.
Old Aug 18, 2007 | 1:15 AM
chelle26's Avatar
should i need to replace my chevrolet pickup headlight assembly since it had scrapes and had minor breaking part??
Old Aug 21, 2021 | 9:52 PM
9wee's Avatar
Default Thanks!
This was very helpful--thank you!
rojeho
Mar 10, 2015 9:41 PM
flyhound
Feb 2, 2014 8:09 AM
la perrona
Jun 15, 2011 9:14 PM
Mr. Vann
Nov 25, 2009 7:24 PM
