Dome lights off and cargo lamp Message says On
Old Feb 23, 2011 | 9:21 PM
chrismx104's Avatar
Default Dome lights off and cargo lamp Message says On
Today I was tryin to get my radar detector hooked up to my dome light power therefore, I won't have to have it hooked up to the cigarette lighter and it can sit up in my tint strip. When I hooked the wires up to the dome light plug in the radar detector came on no problem. Although when I went to push them back I guessing I pushed them too far and they touched each other making it arch and smoke when this happened the dome lights went out and the message display said cargo lamp on and whenever I change the cargo lamp on and off it doesnt make a difference it still has this message. I've checked the fuses that I assume it would be and nothing is blown. Am I missing a fuse or something that I should be checking or what?? Any suggestions? It's bothing the crap outta me
Old Feb 24, 2011 | 2:51 PM
deano 177's Avatar
there is an accessory fuse in the dash pannel and the cargo light is under the hood. Maybe try disconnecting your battery for an hour and let the computer reset. I dont know what else to tell you to try....
Old Mar 29, 2021 | 9:06 PM
Fallon Rogers's Avatar
[QUOTE=chrismx104;173918]Today I was tryin to get my radar detector hooked up to my dome light power therefore, I won't have to have it hooked up to the cigarette lighter and it can sit up in my tint strip. When I hooked the wires up to the dome light plug in the radar detector came on no problem. Although when I went to push them back I guessing I pushed them too far and they touched each other making it arch and smoke when this happened the dome lights went out and the message display said cargo lamp on and whenever I change the cargo lamp on and off it doesnt make a difference it still has this message. I've checked the fuses that I assume it would be and nothing is blown. Am I missing a fuse or something that I should be checking or what?? Any suggestions? It's bothing the crap outta me [/QUOTE
I have a 99 gmc Sierra and it is doing the exact same thing. I changed the bulb in the glove box and now no interior lights work and the cargo dash light will not go off. Its very annoying. I've checked fuses also and no luck. If someone knows something else to try i would appreciate it.
Old Mar 31, 2021 | 12:04 PM
Gumby22's Avatar
Try removing the bulb in the glove box and see if normal operation returns. If it does, there’s a fault in the glove box circuit that’s only present when the bulb is installed and current can flow. The easy fix is to live without the glove box light.
The courtesy fuse (20A) in the instrument panel fuse block is what powers all the interior lamps such as glove box, vanity mirrors, etc.
Funky Munky
Dec 31, 2018 7:00 AM
Chris1998
Sep 22, 2015 1:06 PM
garrett1308
Aug 22, 2015 7:41 AM
19nakrahn99
Mar 4, 2014 7:53 PM
210glenn
Astro
Oct 17, 2010 9:07 PM
