Thanks for the add, help needed
Old Dec 30, 2018 | 7:06 AM
Funky Munky's Avatar
Default Thanks for the add, help needed
I recently acquired a 2011 Suburban LTZ and have stumbled upon a minor issue which is making me crazy.
My cargo area dome light is not working. I checked the bulb, and it was blown so I replaced it expecting the new bulb to light right up- no light. i replaced the bulb again thinking maybeI got a dud - still no light.
All other dome lights work, i have checked the fuses I would guess ties to the cargo dome, but cant find anything wrong.
Is there a fuse the cargo dome is linked to i may be missing? Any suggestion what could be wrong? is ther a switch somewhere i do not know about which controls this dome?
Thanks in advance!
Old Dec 30, 2018 | 9:49 AM
Cusser's Avatar
We have a 2005 Yukon and believe that there's actually a switch for that, so one can turn off that light if the hatch is open (I drive that like 3 times a year, Mrs. Cusser tows with it). So check the owner's manual.
Old Dec 30, 2018 | 3:40 PM
Welcome to the forum.
Did you check the fuses on the end of the dash on the driver side?
Old Dec 31, 2018 | 7:00 AM
There is no switch listed in the owners manual for the cargo light that I can find othet than the dome light override which I understand.
i checked the fuse box by the door, nad the dome fuse, and all other applicable fuses seem to be good. Looks like there is a center fuse box under the dash to the left of the steering column which has 2 fuses labeled headliner 1 and 2. i havent opened this yet, but looks to be blocks rather than mini fuses- anyone know what these control? owners manual did not elaborate.
