Notices
Door dent
Old September 19th, 2012, 9:11 PM
Ciara's Avatar
Default Door dent
I bought my chevy 1500 about 2 months ago, I was backing up in the dark last week and rubbed against a tree putting a good sized dent in the door. It is creased in so I cant remove it with a dent puller tool, and the inner door frame is in the way to try and hammer it out. any idea how much it is going to cost me to get it removed? there are 2 dents about 6"-8" wide and 3"-4" in hight for the larger on and about half that size above it. Im not worried about the paint, that will buff out.
thanks for your help
Old September 20th, 2012, 7:41 PM
grumpychevy's Avatar
I'm not sure if a paintless dent repair professional can get a dent out that has been creased. If not then it will require a dent puller. Old way was to drill holes, put in a sheet metal screw and use a slide hammer to pull it out. Modern way is to weld pins onto the dent and use a slide hammer to pull the dent. As you can see both ways are going to require new paint on the door. My guess would be around $800-$1000 at a good body shop.
corbansky
July 27th, 2011 9:25 PM
jriver85
15
February 5th, 2009 12:41 PM
Quick Reply: Door dent
