door hadles
RE: door hadles
You will need to switch the clip, from the old handle, to the new one, for it to work. Also, the bolt, closest to the access hole, in the door jam, will be 1/2 in lower. Just bend the edge flat, at that bolt, and it will tighten. Start the nut, on the bolt, slide the door handle in position, and tighten it through the access hole, with an open-end wrench. (10 mm?) Also, disconnect the lock rod, from the door latch, so it does not rattle, in your door. Check out http://www.trucksecurity.com and http://www.autoguard.usfor more security ideas. Watch the video link about anti-theft hood latch, on autoguard.
Joels.blacklab
December 27th, 2017 7:48 AM
davbell22602
March 10th, 2010 8:36 PM
aquaholic
November 21st, 2008 1:21 PM
