door panel removal on a 99 silver
Old Apr 10, 2008 | 11:42 AM
neisy13's Avatar
Default door panel removal on a 99 silver
I'm new to the forum. I hope a friend could tell me how to remove the front door panels without damage. I have a noise window with stuff shaking and vibrating inside. Any suggestions? Thank you in advance!
Old Apr 10, 2008 | 12:37 PM
rabbit0102030's Avatar
Former Moderator
Honorably Retired Member of Staff
Default RE: door panel removal on a 99 silver
I have a suggestion:
Don't post the same thing more than once!
Old Apr 10, 2008 | 1:03 PM
northey87's Avatar
Welcome to the forum!!! I believe there was a thread not to long ago about taking the door panel off. Try doing a search and see what you get.
Old Apr 12, 2008 | 2:58 AM
xx13xx's Avatar
ORIGINAL: rabbit0102030
here is a suggestion instead of being lame to someone who is new...try just linking the thread obviously someone that has been around here for awhile knows how to use the search thread...next time try helping instead of just flaming
Old Apr 13, 2008 | 11:11 AM
ehhget's Avatar
Rabbit I agree with Neisy, if you dont want to help dont say anything. When you break someones ***** because they are new it makes you look like an ***.
Neisy- I could not find that link so I just did mine:
There are two screws on the part of the handle that you pull to close your door- one is visible towards the back of the handle the other one in under the panel that holds the power window buttons- remove the rear screw then pop that panel up, unplug the buttons and remove the other screw.
Pop off the little triangular panel behind the side mirror above the door panel-it will be in your way when you lift the panel off later.
Pop out the lower light at the back of the panel and unplug it.
Pop off the little panel that goes around the handle that opens your door.
Pop out the door lock slide button.
Now you have to lift up on the panel while you push in on it to remove it. There are about six plastic molded "upside down hooks" on the back side of the panel that hold it into place by slipping into square holes. Once you push up on the panel enough they just pop out and the panel will lift off. It takes a little force but just push in and up and it should lift off. I started at the bottom and kind of punched the bottom of the panel up as I pushed in and it just came right off. Good luck.
juddkennedy
May 22, 2010 4:28 PM
Bentley
Jan 26, 2007 1:52 AM
Bentley
Jan 24, 2007 7:46 PM
Tomahawk06
Dec 6, 2006 2:23 PM
LeoDuffrin
Apr 27, 2006 10:43 PM
Top
Follow Us
