dragging rear brakes
Old Jan 7, 2013 | 7:48 AM
92spi's Avatar
Default dragging rear brakes
new here guys...thanx for having me. just changed the pads on rear of my 2001 1500 and the brakes are dragging really badly. just slightly at first, but after they heat up it is really, really bad. what gives? looked to be simple to do, but now has me baffled.
Old Jan 7, 2013 | 12:53 PM
Doug Sonier's Avatar
Default dragging breaks
Your roters may be warped and are out of round. Look at the wear on the pads. Is one pad worn more then the other, is there more wear on the top or bottom of the pad etc. You can also check with a dial indicator or a micrometer.
Old Jan 7, 2013 | 3:00 PM
kevinkpk's Avatar
Did you replace the parking brake pads also? I know, maybe an insulting question, but is the parking brake set?
Old Jan 7, 2013 | 3:19 PM
92spi's Avatar
Unhappy
no parking brake set. no drag of parking brake. only 85k on truck; probably first change of pads on rear. just used a c-clamp to push piston back in and whipped the pads on. replaced pad holders, too, just 'cuz they was there. (like climbin' the mountain). don't get this at all. pushed the fluid back to the master, so no collapsed hoses, i guess. caliper kits are next if i can't think of anything else.
Old Jan 7, 2013 | 6:43 PM
Doubt its a caliper if the piston went right in look at putting roters on like i said
Old Jan 9, 2013 | 10:55 AM
92spi's Avatar
sorry it took a while to get back; life happens; rotors look good; almost no runout per dial indicator. pistons are a litle hard to push back in when they get to bottom of travel. chiltons say to loosen bleeder when pushing piston back in w/abs brakes....i'm thinking they mean the front brakes since the rear abs is controlled by sensor in the tailshaft of tranny. someone tell me if i've screwed the pooch by not loosening bleeder. just wanted to check if hoses were collapsed internally, ya know.
Old Jan 9, 2013 | 7:09 PM
92spi's Avatar
rebuilt calipers; cured problem. not a drag anymore.
ivins812@yahoo.com
Jun 26, 2019 9:13 PM
Willdoit
Mar 11, 2014 12:58 PM
JRich_taco
Aug 31, 2013 12:16 AM
Bo Jangle
Dec 17, 2011 5:49 PM
Mille Racer 69
Dec 8, 2010 8:26 PM
