Driverside window and locks inoperable
2004...window and locks will not open w/FOB or at the door controls on the driver side...passenger side works fine w/FOB and at the door...I have checked the fuses and they are all good...stopped working then all of a sudden worked again and now its back to not working....sounds like loose wiring???? But where do I start?
you can check all the connectors on the bottom of switches but you must remove the panel it could also be a short trippin out the circuit breaker killin the power to the door module
I checked the connections at the bottom of the control, they are good. I also followed the wires out of the door and into the cab to the fuse box. I disconnected and reconnected the connection with no luck. Where do I look for a short and where is the breaker box?
the short would probably be in the door behind the speaker some where i think the circuit breaker is in the driver kick panel in the distribution box on the fire wall
k-beau mania
July 16th, 2014 1:06 PM
mattyboy
January 15th, 2013 3:54 PM
davbell22602
March 10th, 2010 8:36 PM
drwalker88
February 12th, 2007 12:25 AM
