Driverside window and locks inoperable
Old Jan 8, 2009 | 4:57 PM
Wolfpack45's Avatar
Default Driverside window and locks inoperable
2004...window and locks will not open w/FOB or at the door controls on the driver side...passenger side works fine w/FOB and at the door...I have checked the fuses and they are all good...stopped working then all of a sudden worked again and now its back to not working....sounds like loose wiring???? But where do I start?
Old Jan 8, 2009 | 8:12 PM
x1cn18's Avatar
Default RE: Driverside window and locks inoperable
you can check all the connectors on the bottom of switches but you must remove the panel it could also be a short trippin out the circuit breaker killin the power to the door module
Old Jan 8, 2009 | 9:25 PM
Wolfpack45's Avatar
I checked the connections at the bottom of the control, they are good. I also followed the wires out of the door and into the cab to the fuse box. I disconnected and reconnected the connection with no luck. Where do I look for a short and where is the breaker box?
Old Jan 8, 2009 | 9:47 PM
x1cn18's Avatar
the short would probably be in the door behind the speaker some where i think the circuit breaker is in the driver kick panel in the distribution box on the fire wall
k-beau mania
Jul 16, 2014 1:06 PM
blaisa
Feb 25, 2014 1:32 PM
mattyboy
Jan 15, 2013 3:54 PM
davbell22602
Mar 10, 2010 8:36 PM
drwalker88
Feb 12, 2007 12:25 AM
