DTC P0155 - Help
Old Oct 15, 2008 | 5:18 PM
Silverado Kid's Avatar
Default DTC P0155 - Help
my 03 silverado had this p0135 error (heater sensor malfunction bank1 sensor1), so i switched the o2 sensor to bank2 just to confirm if the sensor was bad or the wiring and clear dtc. after the switched, the error went with the o2 i switched, it's now p0155 (haeter sensor malfunction bank2 sensor1). this confirmed that the o2 sensor was bad. so i replaced the supposed bad sensor1 in bank 2 and after 15 miles or so check engine light comes on again and still indicating the same error code p0155. i cleared dtc error again after a while it comes on again. i'm now stumped, i was wondering if someone can shed a little light on what might be the possible promlem is? oem sensorwas made bydenso and i replaced it with identical denso also (but part number from oem is different that what i installed which is 234-4668). any help is greatly appreciated.
Old Oct 15, 2008 | 8:17 PM
ukrkoz's Avatar
Default RE: DTC P0155 - Help
http://www.obd-codes.com/p0155
short in harness.
BlazedTrail
Jun 11, 2013 12:11 AM
Jimbos01hd
Jan 30, 2012 12:47 PM
oddduck61
Oct 12, 2011 11:12 PM
