easy access to O2 sensor wire?
Old Apr 25, 2008 | 8:30 PM
northey87's Avatar
Default easy access to O2 sensor wire?
Is there a place in the cabI canget to the O2 sensor wireeasily? I would like to install an air/fuel ratio gauge and really don't want run wires around and under the truck.
Old Apr 25, 2008 | 11:24 PM
RonH's Avatar
Default RE: easy access to O2 sensor wire?
I doubt that the 02 sensor circuit comes into the cab. And which 02 sensor are you wanting to tap? There are probably 4 of them.
Old Apr 26, 2008 | 12:48 AM
hquick's Avatar
This is how I ran mine.
I didn't want to drill any holes in the firewall so...
Through the kick panel, out through the rubber boot where the door wires run, pop out through the bottom of the rubber boot, and go in between the inner and outer guard and drop it own and under the car o the WBO2 sensor.
Old Apr 26, 2008 | 8:49 AM
shawnvw's Avatar
Banned
O2 sensor signal wires will go to your ECM. which is under the hood.
Old Apr 26, 2008 | 11:36 AM
northey87's Avatar
I only have one O2 sensor, Gm started putting more on in '96. Where is the ECM in the engine compartment and what color wire should I be looking for?
Old Apr 26, 2008 | 2:21 PM
northey87's Avatar
Found it, I crawled under the truck and followed the wire, and it goes tothe ECUthat sits behind the glove box in the cab.
Old Apr 28, 2008 | 12:51 PM
jmack91z28's Avatar
Yea I was about to say, the ecm is behind the glove box, and there is only on o2 sensor. Are you still needing to know what color wire northey?
Old Apr 28, 2008 | 1:57 PM
northey87's Avatar
Its purple right? that is what came out of the three wire O2 sensor, red hot, black ground, and purple sensing wire.
Old Apr 28, 2008 | 3:07 PM
jmack91z28's Avatar
Don't get me to lie to you, when i go home tonight I'll look it up in my haynes manual, but right now I don't know.
Old Apr 28, 2008 | 3:47 PM
northey87's Avatar
You don't have to lie I was just double checking, the gauge is hooked up and works fine. Everythings good.
barnesam
Dec 31, 2022 2:34 PM
Simplejack
Feb 7, 2012 7:28 PM
ve4aaz
Uplander
May 14, 2010 9:20 AM
davemec
Sep 14, 2006 11:38 AM
Top
Follow Us
