electrical issue
Old May 3, 2008 | 11:41 AM
drk_drgn's Avatar
Default electrical issue
I have a 91 silverado, when you hit the brakes the seat belt light and buzzer go off. ive looked at the wiring but nothing seems out of place any suggestions would be a great help. Also the brake light stays on, the be=rakes and fluid levels are fine and the light goes off wheni hit the pedal
Old May 3, 2008 | 1:28 PM
northey87's Avatar
Default RE: electrical issue
Welcome to the forum!!! Sounds like a short some where.
Old May 3, 2008 | 5:50 PM
shawnvw's Avatar
Banned
Try disconnecting the buzzer to see if the light keeps coming on when you hit the brakes.
Old May 6, 2008 | 6:18 PM
rjsasaoka's Avatar
I have the CD-ROM of the Chilton's Manual, has a .pdf of the electrical schematics for the '92 Silverado. I have an older year truck which shouldn't be that different so as soon as I get home, I'll look it up and I could send it to you.
Old May 7, 2008 | 12:33 AM
rjsasaoka's Avatar
With the brake lights, did you recently do any brake work on your truck? You may want to double check the drums, calipers and brake lines to see if there is a leak which may allow air into the lines. About a month ago, the brake cylinder for the drum popped the boot, leaking brake fluid all over the place. After getting that fixed, the brake light stays on.
I tried to bleed it once but there must be a lot of air in the rear brake lines and will have it done at the next service for my truck.
As for the buzzer and seat belt indicator, you may want to double check the wire cluster inside the engine well, up against the front firewall and see if there is any water on there, if there is, then that maybe causing the those issues. To resolve it, get 2-1 dielectric spray and spray it down.
That would be my 2 cents...
Old May 7, 2008 | 2:29 PM
drk_drgn's Avatar
thanksfor all the help
dcarlton
13
Oct 15, 2023 10:05 PM
GoGibbs
Aug 8, 2007 7:37 AM
gmlover
Corvette
Mar 21, 2007 5:52 PM
Top
Follow Us
