Engine Coolant Temperature Sensor
Old Nov 17, 2009 | 1:35 PM
joshuasoileau's Avatar
Default Engine Coolant Temperature Sensor
I have a 2007 chevy silerado classic 4.3l v6. where is the temp sensor located? my service engine light came on i brought it to autozone and the computer said it was the sensor, low coolant, or t stat. i cant seem to find the coolant temp sensor.
ok i found the temp sensor and changed it light is still on.
should i change the t-stat?
Old Nov 17, 2009 | 7:15 PM
Speedy650's Avatar
wouldn't hurt. its a cheap fix.
Old Mar 19, 2012 | 4:46 PM
hrob's Avatar
WHre is it located?
Old Mar 20, 2012 | 7:04 AM
Originally Posted by hrob
WHre is it located?
on the drivers side of the block
Attached Thumbnails Engine Coolant Temperature Sensor-2009-11-01_031409_ect.gif
Old Mar 21, 2012 | 11:36 AM
hrob's Avatar
Thanks!...just changed it.
hr
Old Mar 21, 2012 | 9:23 PM
hrob's Avatar
Default Still have a problem with hot starts
I have had a problem with hot starts with my 2000 Silverado 5.3 engine.
It starts right up when cold or within 5 minutes of running at fully hot.
Aftger 5 minutes or so, it takes turning over up to 10 seconds before starting and then it idles rough for a short time. I took it to the closest Chevy dealer and they checked it over and were perplexed having never had a problem like
that. They check the computer, checked the fuel pump (good pressure), cleaned out the fuel lin and installed a new fuel filter. I put this on the internet and someone said it was the Engine Coolant temperature sensor.
I changed that today but I still have the problem. ANY IDEAS?
Thanks
hr
O9aveo5
Sonic (Aveo)
Jun 23, 2015 5:36 PM
penet05
Uplander
Sep 3, 2014 5:01 AM
SEAN
Sonic (Aveo)
Oct 9, 2010 6:44 PM
mgunim7631
Jun 5, 2007 12:49 PM
mazdacaddi
Feb 16, 2007 5:03 PM
