Engine swap
Old Aug 25, 2015 | 1:23 PM
ChucktheTruck's Avatar
Default Engine swap
HI guys im new here so please tell me if this is no where this goes but just had one question before trying to do this swap! I have a 1996 Chevy c1500 with a V8 305 vortec motor. Truck currently has 152*** miles and is in need of a new motor. iv bought a 1993 chevy 1500 that has a 350 TBI. Now heres the question, should i have any problems just performing an engine swap with these two motors?
Old Aug 25, 2015 | 7:13 PM
Richardx2's Avatar
If I am correct you will also have to swap out the wiring harness and ECM due to the fact that the 96 engine has a different fuel delivery system. With the TBI system you also see a decrease in MPG.
Other than that the 5.7L should drop right in and bolt up just like the 305.
Old Aug 25, 2015 | 11:31 PM
Alright sounds easy enough will post back with results, gonna take a shot at it this weekend
Old Aug 25, 2015 | 11:33 PM
Can I use the ECM out of the old truck no problem?
Old Aug 26, 2015 | 2:45 AM
burnhedge's Avatar
Default Engine swap
What trans does each truck have? A 4l60e in a 96 has more electronics than a 93. Not sure the 93 ecm and harness will just drop in and control it properly.
Old Aug 26, 2015 | 7:24 AM
Richardx2's Avatar
With a good wiring harness the older ECM will work. Before the swap take good notes and pictures of the harness and connectors to make sure that you route them so they will reconnect to the sensors and double check the O2 sensor location.
And as burnhedge pointed out ensure the transmissions are compatible, you might have to use the the older transmission also.
Old Aug 26, 2015 | 8:33 AM
Alright I'll check compatability
Old Aug 26, 2015 | 2:25 PM
Some are saying I need to swap the heads and injectors as well? Is this true
Old Aug 28, 2015 | 4:46 AM
Richardx2's Avatar
You could run the TBI setup with the swap of the ECM, the vortec setup is more efficent tho.
Old Aug 28, 2015 | 9:50 AM
Can I take the intake manifold off the 305 and put it on the 350?
